- Nov 29, 2014
- Threads
- 65
- 24,995
Degrease the crank shaft then clean the aluminium off with hydrochloric acid ( muriatic is the same just a lower grade )
Don't leave it sit in there for hours it should dissolve off in about 10 minutes.
neutralize the the acid bath with pool chlorine and it will be safe to tip down the drain ( might be illegal in some places ) .
Then ake some close ups of the big end journal.
usually they cleanup OK but if there are grooves into the surface deep enough to catch your fingernail the journal is toast.
Some times a light polish will be OK but generally it is new crank time.
Once we have determined if the crankshaft needs replacing then it is time to start adding up the parts required and come to a decision..
Was there a rod under the bottom counterweight ?
What does the bottom of the crankcase look like.
And congratualtions well done thus far .
