- Nov 29, 2014
- Threads
- 64
- 24,729
Ordered.
And you cut out all those holes (large and small) with a nibbing tool?
Yeah,
It is one of those punch & anvil types that fit on the end of an electric drill.
Cuts a slot about 2mm wide.
For commonly cut ones I made a wooden template and because the punch runs inside a static tube, you can use the tube as a guide.
Anything smaller than 5mm gets drilled then dressed to exact size with a dremel tool.
Got sick of having composite gaskets for vintage motorcycles crumble then leak .
I still get some made by Lanni at CopperGasketsUS but the hike in postage has doubled the price so I only put an order in if there is 5lbs of gaskets needed so the freight can get amortized over 20 or more gaskets.
