cpurvis
 - Aug 25, 2015
- Threads
 - 21
 - 2,256
Bert,
A new filter does filter better than an old one.
How could it?
Bert,
How could it?
By the way Bert, since you and I have been in this business, something from the manufacturing end we get to be involved in are the claims against the filter manufacturers from all kinds of claims many of which some of the folks may have not had much on the ball. Yet, we have to take every claim seriously as the one we don't can end up costing up a years production run on a line.
We've had claims of bearing failure, claims of washed down cylinders, too lean, too, too, too, too and more of the same. One thing you want to do is go the extra mile to check out each claim. Usually what we'd find and about the only thing we ever found was oil contamination from fuel due to not changing the air filters, thereby causing extremely rich fuel operations. By the way, just one example, we would never get finished discussing all the examples we investigated. If we ever found a problem in any of the brands of filters we manufactured, we wanted it taken care of day before yesterday or even better, last month.
Again, the only place oil is wasted is on the ground. Another way to waste oil is not changing the filters often.
God love you all my friends,
Max
Because the debris on the outside of the filter medium is also filtering the oil and the holes between the debris on the outside end up being smaller than the holes in the filter medium in the first place.
SO it ends up filtering finer particulates out of the oil.
Eventually it gets so thick that the oil can not get through at all so the filter goes into bypass and does not filter at all.
If the filter does not have a bypass then the engine suffers a low oil failure or the oil pump gets overloaded and starts passing excessive oil down the sides of the rotor or gears, reducing its pressure capacity.
Because most filters have a bypass people keep on using them because the oil is flowing OK and they have no understanding about how things work.
That's what I was asking to be explained how that could be true.A new filter does filter better than an old one.
