cpurvis
- Aug 25, 2015
- 21
- 2,256
A filter not only continues to do its job, it does a better job of filtering as it catches debris. With the exception of a clogged, bypassing oil filter, a new filter is actually doing the poorest job of filtering; the very best job of filtering it can do will be at the end of its life.Slomo, 5 times, every hour or two of operation? Seems excessive, and I am curious where does the 5 comes from.
Why not 7 or 3? (I have a fear of even numbers).
Could you share your thinking and explain why a still working filter needs to be swapped out after
an hour or two of operation? I you make a good case for it. I may give your method a shot. Although my mower already
has 3 hours on it, so it could be already shot...
Do you expect the already trapped contaminants in the filter media are able to work loose and come out again
and contaminate the oil stream, unless you remove the filter? Afaik, they are safely embedded in there and cannot go anywhere.
Or, do you expect such a massive number of wear metal particles to be shedded that they totally clog up the filter during a single mow?
I Think of the filter as having holes/little pockets in filter media. Once a contaminant particle , metal or otherwise is captured in there, it is
held there. As long as you have enough empty "holes" left, the filter continues to do its job without imposing undue
restriction.
You are not doing your engine any favors by changing your oil any more frequently than the manufacturer recommends, especially during break-in.
