CraftsmanFlaws
- Sep 4, 2016
- 38
Well I replace around 200 belts a year and none of them would ever be more that 1/4" longer than original.
In place of reading what other people who have no idea what they are talking abut I suggest you talk to the people who make the belts than do not stretch.
The problem with the web is it allows 3,000,000 people who are illinformed about what they are looking at to come up with a totally wrong set of assumptions then by virtue of numbers the falicy become fact.
As I seem to remember a pair of prop makers became multi millionairs by showing the general public all the "truths" that hundreds of thousands of clots on the web had repeated were in fact 100% wrong.
Suggest you get the full set of Mythbusters DVD's then watch and learn.
Mower belts are Kevlar, Kevlar has a higher tensile strength than steel, it does not stretch.
The rubber compound used on mower belts shrinks when it gets to operating temperature
And belts wear thin on the contact faces.
I have cut hundreds of them in 1/2 to show to customers just how much they have worn when comparred to new belt of the same size.
The back of the belt will still be almost the original width but the inside will be a lot thinner.
I have wrapped the customers old belt around a spare pulley then a new one to show them just how much deeper a worn belt sits and in a few cases even weighed a new belt against an old belt to show then just how much their belt has worn.
Furthermore you have displayed your ignorance about what you are talking about by citing a source that has nothing to do with the type of belts you are complaining about.
Machine belts are plain unwrapped belts made from a different rubber compound and usually with either cotton or pollyester cords.
Their compound is very similar to what your tyres are made from and gets quite sticky when hot.
Mower belts do not get sticky because most of them have to be able to slip on the pulleys when you clutch/brake or turn off the blades on a moewer with a manual PTO.
The exception to this are the mowers with cone or cork clutches where standard belts can be used.
Bertsmobile,
I've found mower sites and small engine sites that claim belt do stretch Yes, some say the Kevlar ones do not, but I don't understand how you can say that Kevlar is what OEM tractor belts are made of, and state they are stronger than steel, and then in the next sentence say the "rubber compound used on mower belts shrinks when it gets to operating temperatures." What am I missing here? Are the belts made of Kevlar & rubber both? It seems strange that Kevlar would be used to avoid stretching and provide stronger than steel strength, and then this is defeated by the rubber used which shrinks, and I am assuming is what wears "thin on the contact faces."
