lawn mower fanatic
- Jun 8, 2012
- 6,749
Here in the northern climate ever winter someone gets killed when they run a gas powered generator in their garage attached to their house.
That occasionally happens here as well.
Yes it will cause cancer unless you drink at least 1 six pack of quality beer. Beer washes out all of the carcenogins.
Don't let the EPA get a hold of this question. They will add about 5000 dollars for emissions to the cost of a mower.
Nothing actually causes cancer.
Cancer is a natural occurrence .
I happens when the processes within your body designed to kill off & remove unwanted growth stop functioning.
It all comes down to your genes.
If this self clensing system is very strong in your body you will never circum to "Cancer"
If your self cleaning mechanism is compromised then something may trigger as abnormal growth of your own body cells leading to what we call cancer.
YOU CAN NOT CATCH CANCER
YOUR OWN BODY CAUSES CANCER.
Some external things may
1) compromise your bodes self cleaning mechanism to the extent it fails to funcion properly
2) trigger so many abnormal growths OF YOUR OWN BODY tissue that your self cleaning system can not cope.
Everything eat, drink put on your skin & even breath in triggers abnormal growths . Think of them like a pearl growing in an oyster.
However some things have been found to do this to a much higher degree than others and affect a larger number of people.
These we call castanogens and rightly so tried to reduce mass exposure to.
However as we get more & more advanced methods of medical research we find more and more potential castanoges and eventually everything will be found to be castanogenic so the legislators will decide that we must remove our brains at birth and connect them to a machine that is impervious to these castanogenic agents.
Seriously, if you are liable to develope cancer riggered by the exhaust from your lawn mower they you would be riddles with cancers triggered by the person who smokes 3 blocks away.
Very well said. Liberals are just scared of everything. Scientists think they have a answer for everything and most the time they are wrong, then have to change the so called "facts" over and over. These people can't understand that nobody lives forever.
Global warming is the dumbest ideology ever though of. When the average temps are lower than normal they call it global cooling. So the earth is warming up or cooling down? Then they had to change it to climate change lol.
These frauds want you to believe that every day of every year should have the same temperature, like the average temp of that day is what is should be every day. Its normal to have occasional warm days in the winter and cool days in the summer but they want you to believe this just started after we started burning "fossil fuels".
