Ric
Mid to premium gas shortens the life of small engines from what I was I told.
The section below is out of one manufacturers manual and I sure you'll find it in others, and if for some reason the Mid-grade gas in your area has a lower than 89 octane rating then you need to switch to premium gas. I think it's pretty much known that most engines, lawn equipment, car or truck will most always run better on higher octane gas.
Use mid-grade unleaded gasoline with a
minimum octane rating of 89 (R+M/2)
and no more than 10% ethanol content.
Fuel with a lower octane rating may
increase engine temperatures. This, in
turn, increases the risk of piston seizure
and damage to the engine.
