MTD-B&S 6.75 HP help to stay running
silver1
I have a MTD or Weedeater walk behind that will start when pumper/primed and I can keep it running by pumping the bulb
on the carb. It does have a bowl on the carb. but hard to get to. Does it have needle and seat? The fuel tank leaks at
the seem by oil fill. What is a good sealant?
120602 0131 E1
LB
reynoldston
The best sealant I have found for gas is called seals-all. It comes in a yellow tube and can be bought in most hardware stores.
davbell22602
Does that hold around heat and gas? How will it hold up?
reynoldston
As far as heat go's I don't know. I have been using it for years on gas tank repairs on cars and trucks. One of the things I do find it works best on a clean surface. Its called Seal-All and if you would like to more just look it up on the Web. eclecticproducts.com
silver1
$5.99 @ Autozone. Thanks
Fish
Just replace the tank with a good used one, if you got one off of e-bay it would cost just a little more than the sealant that you will buy. Just try removing the nut on the bottom of the carb, and cleaning all of the holes in it first. Don't fuss with the bowl much, with luck it will stay stuck on the carb while you do this. The little holes
in your nut/jet will likely be scummed over a lot with varnish goo, partly from the molten baggie juice from the gas cap area. The molten plastic will eventually destroy
your engine, so you may want to get that new/used tank soon...
To solve your carb problem, you are going to have to remove the carb and give it a good cleaning. When you reassemble it make sure that you install a new float needle and seat. Briggs part number 398188. What has happen is the seat has expanded and when the needle shuts off the incoming fuel it does it to soon and the level of fuel in the float bowl is not high enough for proper operation.
