Fish
- Aug 2, 2013
- 11
- 5,143
Just cleaning the carb and installing no new parts is just temporary band aid fix and will not last long.
Why is that!!!??????
Just try removing the nut on the bottom of the carb, and cleaning all of the holes in it first. Don't fuss with the bowl much, with luck it will stay stuck on the carb while you do this. The little holes
in your nut/jet will likely be scummed over a lot with varnish goo, partly from the molten baggie juice from the gas cap area. The molten plastic will eventually destroy
your engine, so you may want to get that new/used tank soon...
Wow!!!! It is almost like someone posted this......
The main tube was plugged up also, so removal was a good thing.
get rid of the baggie![/QUOTE,
Temperary its gone
