Old vs new size comparision
Kingwood990
From left to right 2000 Yardmachines lawn tractor, 2006 John Deere X520 garden tractor, 1974 MTD 990 super garden tractor
John Deere X520 vs MTD 990
Vintage lawn tractor vs garden tractor
From left to right.
1978 Sears GT/11 and MTD 990.
JDgreen
Really interesting, wish you could figure out the weights of those machines and post that to give us an idea of how downsizing has affected weight of newer machines. The brochure for my '89 vintage Deere 318 lists the dry weight at 838 pounds, tractor only. I think you would have to buy a really big, expensive Deere these days to get to that weight figure.
Kingwood990
Here's the weights of each machine. Give or take a few pounds.
The Yardmachines is about 450-500 pounds.
The little Sears GT/11 is about 600 pounds.
The John Deere is 856 pounds dry with 54'' mower.
The MTD 990 is 1015 pounds dry. I know this weight is correct because this machine has rolled over my foot before.
JDgreen
Thanks...my older JD weighed within 20 pounds of yours WITHOUT the 50 inch deck installed....and the deck on mine weighed about 185 pounds, which means Deere took a lot of material out of the newer machines.
Muhammad
Administrator
Staff member
These days the engineers really have to work to maximize efficiency and I think the weight is one area you see that. Some would make the point that a lighter machine is better for the lawn as it won't compact as much or tear up lawn as badly. But as soon as you go outside of mowing, the lighter weight becomes a liability.
As for rolling over your foot... OUCH! :eek:
Kingwood990
The deck on mine weights about 150-170 pounds. The deck is very think and all steel. The tractor has more plastic body panels than steel. Over all the machine is well built with the exception of the plastic hood. If it had steel hood I would love this tractor even more.
Kingwood990
This is true.
I used to mow with a much lighter machine and would get stuck a lot. Also it would spin on wet grass and tear up the yard. Now that I have a heaver machine those problems disappeared.
Oh the orange tractor does not have any brakes. So it likes to use what is the closest which is me.:mad:
I have to get the brakes working on it someday.
KennyV
With much lighter weight you can (and they DO) use bushings instead of wheel/axle bearings. This goes even deeper into the drive system... The transmissions can be bushed.
Engines do not have to be built to deal with constant torque loads... Steering is built much lighter. Everything goes down Cost, quality life expectancy, And you end up with a under $2000 rider or a under $3000 ZTR.
In MOST cases this will not be a problem for the average residential user. BUT when someone gets the idea that they can get one of these light weights to do even mild commercial use, or large acreage... They are only kidding themselves.
AND these are the users that give the various mower manufacturers a bad name. They are buying the wrong tool for the job they have in mind.
Manufacturers will make the lighter models 'LOOK' like the commercial lines, from a distance.
You will find the same thing in tool makers... I'm sure you have seen hammers that sell for a dollar, at a glance you will identify it's a hammer... but don't compare it to a $30 framers hammer.
The older riders were down scaled tractors... and they have lug nuts that bolt the drive wheels to hubs on the axles... the front wheels are on wheel bearings, and the steering linkage has ball joint or hymen linkage...
Used within the design limits the light weight equipment will do the job for some folks...
BUT if you want it to last the best part of your lifetime, buy an actual commercial grade machine. Then you will be 'occasionally' repairing rather than replacing... :smile:KennyV
PS.. I'm an old geezer ... I like OLD machines, have several, just because they are fun and easy to look at....
JDgreen
Very well stated, Kenny...and you can actually WORK on the older models without needing a fancy-shmancy manual or special tools...fuel injection on a lawn tractor....inane, give me a carb any day.
Might not be as reliable but I can rebuild a carb if I have to.
Kingwood990
This is true. I don't like working on the John Deere because it is so new.
The other stuff I have took apart and rebuilt a few times. Just for fun.
