djdicetn
Wow! You must have read my mind!! I was thinking about cleaning the underside of the deck just this evening and I was going to ask how you clean your mower deck and how often you do it. I really want to take care of my new toy...
It will be stored in a utility shed I have out back as there won't be room for it in the garage. (Yes I am one of the few people in Florida that actually keeps cars in the garage). I will have to run an electrical service to the shed so I can dehumidify it. The salt air and humidity here eats up everything!
I also stocked up on plenty of ethanol free 90 octane gas for the Gravely and the rest of my lawn and garden equipment. (I also use it in my motorcycle). I really don't like some of the things I have read about the negative effects of ethanol on engines that aren't used daily, especially anything with a carburetor. I know there are additives to deal with ethanol but why bother when there is a station that sells the ethanol free stuff nearby.
I'll call the dealer tomorrow and ask about the MoJack as well as the mulch kit. If it works on your Kentucky Fescue it should work really well on my St. Augustine (What most folks up north consider crab grass)... I also found several tow behind dethacthers on line as well as some plug aerators I would like to add to my lawn arsenal so I will need the towing attachment as well.
Today was a beach day for me and the wife so I didn't get a chance to take any pictures before it got dark but I will post them soon!
JJ
When I first used my Pro Turn 152 last Fall and early this Spring there really wasn't any buildup underneath the deck(just a "green stain"). As the middle of the growing season approached, I noticed a slight buildup in a few areas and I just used a wide putty knife with the deck raised all the way up. I've only used the mulch kit the one time(and the grass was VERY wet) but I had to use a hose to spray the clipping buildup from underneath the deck after letting it cool down. I may have to clean underneath the deck more with the mulch kit ongoing, but a couple of more mowings without the grass so wet will reveal that need.
I don't know whether your dealer will carry the MoJack or not, but I'll paste a link to Lowes at the bottom for you to see what they look like(they also sell them at TSC I think). You will find that jack invaluable for sharpening blades, etc. Looking forward to some pictures!!!! Here's that link:
Shop MoJack Tractor Lift at Lowes.com
