Carscw
- Aug 11, 2011
- Threads
- 66
- 6,375
Ethanol does not cause small engine problems. There I said it. Ethanol is actually a solvent, which in other words is a cleaner. The problem with ethanol is its love for water. Ethanol can absorb up to 1% water before it separates out of the gas. which also lowers the octane of the fuel about 2 octane. The water contains desolved minerals that interact with the water and the ethanol and form a mild acid, similar to vinegar. The vinegar slime, water mix causes corrosion to aluminum and steel parts of engines, and with todays fine tuned, microscopic passage carbs, it takes very little corrosion to cause blockages of those passages.
The people that run large amounts of fuel through there equipment will not see problems with there engines. There is enough fuel exchanged to prevent phase separation, and the cleaning properties of the ethanol actually help remove any deposits that have accumulated. The problem is more pronounced in equipment that sets for periods of time, and I am not even sure that draining the fuel, which will leave a small amount of fuel in the carb, doesn't accelerate the problem in some cases, because of the added oxygen in the fuel due to the ethanol.
Twenty years ago techs such as myself were dealing with adjustable carbs, very little ethanol fuel available. but would see water in carbs, and fuel tanks, which if was allowed to set for a period of time would cause rust of metal parts. what we are seeing now is carbs are white internally, with aluminum oxide corrosion, and they look like the have been setting in an acid bath. The main thing that has changed with fuel over the period of time is the additional availablity of ethanol enriched fuel.
The fuel lines that are being used on most equipment are not designed for continuious exposure to solvents. Try putting a piece of fuel line in carb cleaner for a period of time and see what happens. it will either soften, swell if rubber, or harden and shrink if made from a plastic material.
Thank you sir.
I think now we can put this to rest as you have gave us the facts we have asked for.
You post was easy to read and understand.
Thank you for taking your time and putting this in away we can all understand.
