- Nov 29, 2014
- 24,995
You just don't seem to get that $ 4000 is peanuts when it comes to ride on mowers
The good ones start at $10,000 and go up to $ 30,000
And not every mower deck combination will cut every type of grass
It is very difficult to make decks that do work properly on every type of grass and physically impossible to make a deck that will cut perfectly as a bagging, throwing & mulchjing deck.
Any by the way, a lot of push mowers leave stragglers behind as well although this is down the reduction in blade tip speeds particularly on the bigger 20" o 24" decks
Profit margins are very low at the bottom end so they are not going to spend $ 500,000 designing a perfect deck
If you don't like it then that is just tough luck.
You got the wrong mower for your situation .
And if you can not see that the air flow charactersitics under a 2 or 3 blade deck will be vastly different to the air flow under a single blade deck then there is nothing I can do to rectify that.
The days of making quality products for peanuts is gone, not that it ever existed .
I am actually sorry that your mower has not lived up to your expectations but if you had of asked here first they you would have got an honest appraisal.
When faced with the alternatives of spending $ 2,000,000 on dvertising to convince you that a particular mower is perfect ans spending the same $ 2,000,000 in reserach & design, well the advertising wins out every time .
That is the nature of a capitalist market with little consumer protection and a market that can not make an informed decision because the true facts are never revealed to them.
Mass market mowers are made to make profits for shareholders not to cut every bodies grass perfectly.
If you want top quality then you have to pay top dollar it is as simple as that .
