- Nov 29, 2014
- 64
- 24,702
No rotary can cut grass then leave it just where it was cut
Todo that you need a scissor action so you are looking at a barrel mower or a sickle mower
The first give the best cut but require a lot of work to keep the cutters sharp and will lot tollerate the smallest of sticks or really tough grass
The second is cumbersome , again requires a lot of work to keep the blades sharp and is easily damaged
Flail mowers are the best all round at this but AFAIK the only small flail is an option on the Husqvarna P524 articulated out front mowers which down here lighten you wallet by $ 30,000 ( aus ) .
Just because you want some thing does not mean that some one will make it for a price you are comfortable paying.
Cheapest solution would be a used Walker or GrassHopper if it has to be a ZTR
Otherwise there are quite a few rear discharge tractor style mowers , with or without catchers .
I think the Stiga's are the cheapest
