gregjo1948
- Nov 28, 2012
- 75
- 361
working on an older IS3100 That I had to do some engine work on. Engine is repaired and running fine, but the machine won't move. It's been sitting since July 2022. Has the correct fluid in the pump reservoir and the releases are in the right position. It was driven to where it is sitting now and moving as it should. Would appreciate any help, gregjo1948
