- Nov 29, 2014
- 24,995
NO NO hydros in the drive position, not the bypass ( push ) position .So if you couldn't even begin to push it (before knowing the hydro had to be bypassed) then it's probably okay too.
And of corse brake off.
The wheel should roll in the same direction
If they roll in opposite directions then the parking brake is jambed on .
