Won’t start...what’s this connection?
millennium3
Fairly new mower, Poulenc Pro 17.5, was running fine then just died. Turns over but won’t start.
Any ideas where this connection (blue/black wires) goes??
Check for spark, put a tablespoon or two of gas in the cylinder, or spray some carb cleaner in it, reinstall spark plug and plug wire, try to start. If it fires then dies, fuel problem, if NO fire, most likely NO spark. Next locate the ignition coil, there should be a small, usually black in color Kill wire hooked to it, unplug it. Then repeat the above steps and try to start. If it fires, then there is an electrical issue grounding the coil. If no fire with the kill wire unhooked, bad coil
Thanks! Have fire. Cleaned carb twice. Continuing fuel search
