Won’t start...what’s this connection?
millennium3
Fairly new mower, Poulenc Pro 17.5, was running fine then just died. Turns over but won’t start.
Any ideas where this connection (blue/black wires) goes??
Most likely that is part of the harness for the lights.
Scrubcadet10
Moderator
Staff member
Check for spark, put a tablespoon or two of gas in the cylinder, or spray some carb cleaner in it, reinstall spark plug and plug wire, try to start. If it fires then dies, fuel problem, if NO fire, most likely NO spark. Next locate the ignition coil, there should be a small, usually black in color Kill wire hooked to it, unplug it. Then repeat the above steps and try to start. If it fires, then there is an electrical issue grounding the coil. If no fire with the kill wire unhooked, bad coil
millennium3
Thanks! Have fire. Cleaned carb twice. Continuing fuel search
Scrubcadet10
Moderator
Staff member
Do you know the engine model number?
