You are correct!! Thank you. Had the hood off.Most likely that is part of the harness for the lights.
Thanks! Have fire. Cleaned carb twice. Continuing fuel searchCheck for spark, put a tablespoon or two of gas in the cylinder, or spray some carb cleaner in it, reinstall spark plug and plug wire, try to start. If it fires then dies, fuel problem, if NO fire, most likely NO spark. Next locate the ignition coil, there should be a small, usually black in color Kill wire hooked to it, unplug it. Then repeat the above steps and try to start. If it fires, then there is an electrical issue grounding the coil. If no fire with the kill wire unhooked, bad coil
Do you know the engine model number?
Does this carb have an electric fuel shut-off solenoid on the bottom of the carb bowel?Thanks! Have fire. Cleaned carb twice. Continuing fuel search
Yes it doesDoes this carb have an electric fuel shut-off solenoid on the bottom of the carb bowel?
Saw how to test with 9v battery but haven’t done that yetYes it does
