The most "expensive" maintenance procedure I have is changing the hydraulic fluids on the zero turn and tractor.
I
Travis, if I had that synthetic mobil1 you drain from your hydraulic system... I would filter it and blend with my diesel fuel...
You are right about DIY it gets things done right and is very satisfying ... :smile:KennyV
