Up until about 18 months ago I never ran anything out, never used fuel stabilizers, and kept two stroke mix all through the winter and used it up in the spring. I did not have many problems. But all of a sudden I had nothing but problems all fuel related. About that same time I discovered that many engine makers seem to consider anything carb related to be the fault of the gas you run and do not warranty their fuel systems very well and the newer they are the more picky they seem to be. I think it is going to be much worse over the next few years. So I became real religious about fuel stabilizers, fresh fuel, fuel containers, higher octane fuel, fuel without booze in it, and off season storage. i also began to talk to classic car owners, motorcycle folks, boaters, and neighbors. Some of the stuff they showed me was pretty amazing. A bottle of fuel stabilizer is pretty cheap. Honda engines are known to be expensive to repair. Many two stroke oils have stabilizers in the mix. If they were not a good idea then I do not think they would put them in the oil.
What is a good brand of fuel stabilizer to use?
