I have a couple older gasoline mowers... I do not do anything special for the off season, at spring I change oil and everything starts right up... I've never had the type of gasoline problems others have described...
so to answer your questions... shut off the fuel if it's convenient and run them when you need them... otherwise just let them rest till your back to running them regularly... try to use up all your mixed fuels, I use to burn that up year round, so never had any quantity just setting around aging...
I have had some fuel lines inside chainsaw fuel tanks fail... but I think that would have happened with age with OR without fuel in the tanks.... :smile:KennyV
I have a lot of 2-cycle oil/gas mix in a container. Would it still be good when I need it in April?
For winter storage I wholeheartedly agree with the advice given by user possum. Being a boat owner(bought a 1999 Sprint Fish n' Ski with a 125 Merc outboard new and has been garage kept ever since the purchase), before 10% Ethanol gas was forced down our throats by the EPA I ran nothing but Premium grade gasoline in everything I owned that was gasoline-powered(car, truck, boat, lawn/small engine equipment). Never used any stabilizer and NEVER had any fuel-related problems with anything stored over the winter(I just disconnected fuel lines and ran the boat & other small engine equipment until they ran out of gas to empty the lines and carbs). But things have CHANGED with the Ethanol(including engine design to accomodate 10%). When I replaced my 1993 Lawn Chief lawn tractor(16hp B & S Vanguard-best 4cycle engine I've ever owned) with a 2006 Craftsman(Husqvarna) with a 24hp B & S Intek and put Premium(w/Ethanol) gas in it the thing would barely run, backfired, hesitated and generally ran ragged. I switched to Regular grade and it ran MUCH better. IMHO, that had to be a "design change" by B & S between 1993 & 2006 to "accomodate" Ethanol. And as pointed out by user possum, the Owner Manual for my new Gravely has in bold print on the front cover "any gasoline with a greater than 10% Ethanol mixture will VOID THE WARRANTY". If that doesn't tell you that Ethanol is for all intents & purposes "bad for gasoline combustion engines" I don't know what does!!! The manual also "recommends" the use of stabilizers in the gas. So I, like many others, have become sensitive to protecting all of my gasoline powered equipment. For my car & truck I still use premium grade 10% Ethanol gas(the non-ethanol is cost prohibitive) and treat every other tankful with Lucas Ethanol treatment(BTW, I just replaced the electric fuel pump in my wife's 2001 Lincoln LS costing about $550...."requires" Premium and basically designed by Jaguar "pre-Ethanol" at that time) and had not used the Ethanol treatment since 10% Ethanol gas became predominent. For my boat, lawn equipment and all small engine equipment(especially my brand new Gravely) I run NOTHING but Regular grade non-Ethanol gasoline even though it is a LOT more expensive that the 10% Ethanol gas(and as of right now is still readily available in my area of Middle Tennessee). I will continue to do that as long as it is available and if the EPA shuts down the few "mom & pop markets" that carry it and force them to sell 10% Ethanol I will begin the Lucal Ethanol treatment additive in every tankful in that equipment. Have I told you how much I hate the EPA for mandating Ethanol in gasoline???? If there was a Preidential candidate that had a platform that stated he/she would make the EPA stop forcing Ethanol on us they would get my vote I don't care what party they represented!!!!! Anyway, as it stands I agree with user Possum & others that fuel stabilizers(and possibly Ethanol treatment additives) are all we can do to protect our investments!!!Up until about 18 months ago I never ran anything out, never used fuel stabilizers, and kept two stroke mix all through the winter and used it up in the spring. I did not have many problems. But all of a sudden I had nothing but problems all fuel related. About that same time I discovered that many engine makers seem to consider anything carb related to be the fault of the gas you run and do not warranty their fuel systems very well and the newer they are the more picky they seem to be. I think it is going to be much worse over the next few years. So I became real religious about fuel stabilizers, fresh fuel, fuel containers, higher octane fuel, fuel without booze in it, and off season storage. i also began to talk to classic car owners, motorcycle folks, boaters, and neighbors. Some of the stuff they showed me was pretty amazing. A bottle of fuel stabilizer is pretty cheap. Honda engines are known to be expensive to repair. Many two stroke oils have stabilizers in the mix. If they were not a good idea then I do not think they would put them in the oil. Most engine makers want you to use a stabilizer. If it was me I would buy some fresh fuel at the end of the season add some stabilizer and run them awhile before I put them away. It just seems to me to be cheap insurance.
My Echo oil mix to add to the gas for the 2-cycle oil says it has a stabilizer in it. Does that mean I do not need to do anything with it?
Yes the stabilizer is porportioned for your gas mixture. No need to add more. :thumbsup:
What is a good brand of fuel stabilizer to use?
I found this link about Sea FoamI use STA-BIL also and it has worked very well for me. However, my neighbor uses Sea Foam and swears by it. I use Sea Foam in my car and truck and use it once in a while in other stuff. I think it more of a cleaner, but maybe I wrong.
lawn mower fanatic said:Since November I have been taking my mowers out if I haven't used them in awhile to run them. I do it once a week. Now I decided to turn the gas valve off, run the gas out of the carb, and store the mower, keeping the gas that is in the tank. I will try to run the mower maybe once a month, but I was wondering if this is OK for the mower. Or would it just be a better idea to run it once a week without running the gas out of the carb?
Drain the tank and run it out of gas. The gas in the tank will go bad no matter if you run it once a week or not unless you stabilized it.
You are making it far harder than it is. And alot more complicated. If the carb is already empty then what in the world are you worried about the gas tank being empty? What differnce will it make to drain the gas out now and draining it out come spring? Drain the darn gas from the tank and burn it in a car, snowblower, something this winter. Just get it out of the tanks and get rid of it. Run your engines dry, put a squirt of oil in the spark plug hole give it a couple pulls and park them. Now forget about them until its time to get ready to mow. Like my Dad always said about cows. Prepare them for spring, turn them out, make sure they are there and leave them be. Same with the lawn stuff, prepare them for winter storage and leave them be. Go blow snow, rake yards, drink coffee, trim trees, visit on the internet, look at new equipment, argue about Honda versus Toro, MTD versus Poulan, Chinese engines versus Briggs and Stratton, and HDEO versus PCMO. If you keep up all your worry you will die far to soon and we will all miss you. Most of my friends died this summer, all of them were very worried about the coming election. None of them got to vote. One of them was worried about his girlfriend and she has already found another fellow. One of them was worried about his van and his worst enemy now owns it. One of them was worried about the state of disrepair of the cemetery and he now is buried in it. I hope you get snow for Christmass. We are supposed to get some tonight.
OK thanks for the info. Yeah, I heard about the storm out west. We are supposed to get rain/snow on Christmas, so pretty much a mess! But they will change there minds a couple times from now to then so hopefully they change it to snow! :licking:
I'm glad I don't have to worry about all this winter storage crap.
it depends where you leave your 2cycle stuff. if its in like a garage where it doesnt get to cold you just run the fuel out of the thing so the gas doesnt eat and crust up the lines. sometimes butting a bag around the engine to keep out some of the moisture is a good method. but running your mowers like once a week isnt a bad idea.
See I was thinking that it was a better idea to just run the gas out of the MOWERS because the gas will go bad (even if you run it once a week), and that is my most important equipment. For my 2-cycle stuff I was just going to run it once a week.
There's nothing wrong with running your mowers weekly. If you run them weekly just leave enough gas in the tank to do so for a month. The other thing I have too ask is why do you think gas only last for a certain period of time. As far as your 2 cycle stuff I really wouldn't worry about those, the oils like Echo and Stihl and Homelite and most, all have fuel stabilizers in there oil.
store no gasoline for longer than 30 days UNLESS you use fuel stabilizer on 4 cycle gasoline
I don't feel like doing a lot with it, so will it be OK just running it until it stops? And then just putting it away? I will get it serviced in February.
The problem is that little bit that remains in the carb float bowl can still be in contact with the jet and clog it up. It's very easy to just quickly remove the drain plug and then screw it back in, and you can catch the little bit of gas in a small bowl and toss it outside where it will quickly evaporate.
well your weed wackers wont need to be ran over the winter so drain the gas out, so the fuel lines dont get gunked up, but wont you use your blower for blowing light snow? you wont need to do that since youll be running that every once in a while.
Yes, I will use my blower for light snow. My main concern is my mowers because without them I can't do anything. My older weedwacker has lasted 25 years without draining out the gas, so I won't worry about that!
Do you use echo oil for mixing your 50:to1 mix. If so it has fuel stabilizers in it so your 2 stroke stuff shouldn't be a problem, you shouldn't have to drain them but I'd still run them once in a while. If you're not comfortable with what I'm saying don't do it. You do what you think is right. You can always go with the sta-bil that everyone talks about.
I have been using SeaFoam for a couple of years in everything, trimmers, chainsaws, lawnmower and everything else. Every Spring it all fires up first try and runs all summer just fine. SeaFoam 1oz per gallon of gas.
As a small engine mechanic I'm pretty familiar with the fuel problems we've been having the last few years. For winter storage I use Sta-bil fuel stabilizer in everything. Add it to the tank and run the machine long enough to completely circulate it through the carburetor. I don't have any starting problems in the spring. I also add it to my fuel cotainers, again no problems.
How much should be added to the tank? I have some, but it states for 3 liters and something like 75 liters and I am not sure how much gas I have in my mower's tank. Do I just poor a shot and mix it with a stick and let the machine run for a while?
Not sure on that as I add it to my gas cans when I buy gas. I think I use 2oz to 5 gallons of the red Sta Bil. You could look at the specs for your gas tank and approximate it from there. However I will say the previous owners of out house left us a bottle of "Honda" stabilizer that said it was made by Sta Bil. I've been dumping it in a huge shot at a time to the push mower and it doesn't seem to care. I don't know if you can add too much.
Yea, that is my main concern. If too much can harm. Thanks for the help!
This is my first year for electric start. What about the battery? I plan to remove it and store it on a shelf in the basement. How often do you top off the charge?
I have a portable "jump starter" that I have kept keep in the unheated garage or trunk of the car and it has never failed me after 7-8 years. I top off the charge on that about once a month. I know the clock is ticking and batteries do not last forever.
As far as gas goes, I always run the tank dry and use it in the snow blower. It is basically fresh gas year around. The generator uses 92+ so I do use stabilizer in that tank and I do not store more that what is in the tank.
I have had no problems with gas...so far...knock on wood ...etc.
I no longer have any oil/mix engines
Ps: Do you put your riders on blocks over the winter? Mine will be stored outdoors under a fitted cover.
Varnishing.
He told me that the old carb was so varnished up that there was no hope for it at all and tossing it was all there was for it.
