FALL 2014 UPDATE: things have changed!
Hey y'all. Just joined the forum, researching battery lawn equipment for lawn crew and hoped some of you lawn pros could weigh in.
These posts are 2 and 3 years old and almost universally dismiss battery mowers from back in the day: heavy, low power, slow charging.
But in my recent investigation Li-ion batteries seem to be on the brink of transforming cordless equipment. Specifically 40v and 56v swappable light-weight batteries in 4ah and 2ah formats, run times as much as an hour, and super-charging in as little as 30 min. Batteries and machines are light weight (60+lbs vs 90+lbs for gas), much quieter (60db vs 95+db). And of course the usual bullet points: no oil + gas + filter + spark + carburetor + prime + choke + heat + fumes + exhaust + CO2 pollution + excessive noise.
Looking purely at performance (cut quality, power, mulch + bag + chute, battery life, charge time) and for the sake of argument, ignoring cost for the moment (up to $500 for top-of-the-line battery mowers!), I've been taking a serious look at Ego (
EGO Power+ - Power Beyond Belief also available at HomeDepot) and GreenWorks (sometimes rebranded as Kobalt) (
Greenworks Battery Powered Lawnmowers, Strimmers, Leaf Blowers, Drills and Power Tools, Lithium-Ion 40 Volt - Greenworks also available at Lowe's).
Greenworks has been around for 3 or more years as far as I can tell, and have an impressive array of compatible battery swap tools. But despite very positive reviews on some sites and equipment review webcasts, Lowe's appears to have stopped selling the Greenworks mowers in favor of their identical Kobalt siblings. Not sure what that means.
Meanwhile,
Ego has the best marks in the cordless mower world by far and has raised the bar from 40v batteries to 56v, putting their power performance on similar footing to gas mowers, in some reviewers' experience.
And of course there's B+D and Toro and other veteran lawn manufacturers with their own offerings and seasoned customer service + parts + repair that are trying to keep up with the new breed.
So ... wondering if any of you lawn pros are running battery mowers / blowers / trimmers / saws. Which? Performance? Recommendations? Should I invest in these new machines?
Very gratefully,
Luke
