reynoldston
- May 23, 2011
- 5,705
There is also the cost of electricity each time you recharge the battery. But that is also pretty cheap, I seem to remember figuring about $0.25 per charge once when I used a meter to measure the charge cycle on my Black & Decker mower.
If you are figuring out $0.25 per charge you sure keep track of your money better then I do mine. I wouldn't even give it a thought. So charging the battery 8 or so times you could buy a quart of engine oil and the next 8 charges a gallon of gas.
