reynoldston
- May 23, 2011
- 92
- 5,705
You can't use a nail to balance a blade because #1 you can't put the blade back on the nail in the same spot twice in a row, #2 when you set the blade on the nail depending on the size of the blade you can already be up to 3/8" out of center. In order to sharpen the blade correctly you have to find the center of rotation and a cone does that. Tecomec makes a balancer along with Oregon or Stens reasonably priced or Magna Matic if you want to spend a bunch of money, all wall mount applications. The thing is an out of balance blade will not only or can cause vibration it can also effect the cut of the mower.
And for less then 5 dollars you can buy a balance from E-bay. If cared for will last a life time
