Ric
- May 7, 2010
- 142
- 5,765
What would you recommend?
A_tank96
I'd just buy the Oregon 3 n 1 mulcher blades. There going to last as long as the others.
A_tank96
...they do make a gator blade for it ...
Oregon as you found makes gator mower blades that will fit most everything. Just have to look them up.
Also from their link at the "where to buy" dropdown, you can find where to get them on line or at a local to you outlet...
If you can get the size you need in the Fusion blade:thumbsup:... Get it, some folks on this site do not understand hard surface steel, but they also have problems understanding synthetic oil so I am not too surprised. Get the Fusion surfaced blade You will appreciate the edge over a regular carbon steel blade. :smile:KennyV
What is your length, width and the hole dimentions?''Can't seem to find it with the one that has two small holes and a big one in the middle :frown:
You will like them, for the little bit of price increase you'll get a great hard surface... plus after you have worn away the HS there is Still a good carbon steel under it... :smile:KennyVI use the 3 in 1 blade
I will get a set of the fusion and see how they stand up.
I cut around 200 yards with the 3in 1 and sharping them 4 times.
I only sharping when needed and only replace when the back fin breaks or is about to.
In three weeks or 200 yards I will post back how they did.
(( racing is the only sport that you need two balls ))
Ric they do make a gator blade for it found it now its a 3 in 1
I've been thinking about trying one on my snapper hi vac with a 7HP Briggs intek. You think it would work ok on that? Do they work better with the mulching cover installed or with the side discharge chute? I'm still working on getting it running since I got it, so I haven't mowed with it yet, but the stock standard lift blade on it is pretty much shot.
