What Going Rate for Scrap Metal in Your Area?
davbell22602
Aluminum is way down here too it seems copper is the big thing right now.
Aluminum is way down here also. I remember 5 years ago aluminum wheel with no tire were getting $40-60 each and aluminum wheel with tire was $30. Now aluminum wheel with no tire is $30 and aluminum wheel with tire is $12.
Yep hold on to them, and wait to see if they go back up is all you can do.
midnite rider
I'm a bit surprised that the difference between steel and aluminum is so small. I would have thought that aluminum would be 3x or even 5x the price of steel.
But then I know nothing about the scrap business. :laughing:
Maybe cost is why the new Ford F-150 pickup is going to be all aluminum body and bed as well as in the engine block and parts of the frame. A 500# to 700# weight savings which equates to better fuel economy and performance. There will still be questions of its structural integrity that only time will tell.
davbell22602
Called 2-3 weeks ago and scrap was down to $7.50 per 100 now in my area.
jakewells
220 per ton. been that way since december.
Mikel1
Same price here, aluminum .40 per lb, brass $1 per lb, unstripped copper .50 per lb. Stripped copper was over $2(don't recall exact price).
Two-Stroke
Is cast iron worth anything? I recently removed some cast iron drain pipes from my house. I'm remodeling a bathroom and most of the old stuff had to go.
It's incredibly heavy. :shocked:
