Voltage regulator
RYANS'
I did it, made a plug from a connector block, used a wire to complete the connection loop. Charging at 14.5V. Saved $68. Cost $9.
RYANS'
Pic
Auto Doc's
"Necessity is the mother of invention" (Plato)
That looks pretty interesting, but it works and that's what counts Now you need to take a little clear silicone and seal up all the exposed connections to prevent dirt and moisture from creeping in and ruining your progress.
I take it that the twisted rear wire is just a retainer. Is that correct?
RYANS'
Yes correct. Thanks for the advice, I will indeed. On to the next one.
Carful the brand and formula used here. Some contain vinegar which as we know is an acid. Will corrode things in short order. Read the ingredients first.
