RYANS'
- Jun 15, 2022
- 80
Yes correct. Thanks for the advice, I will indeed. On to the next one."Necessity is the mother of invention" (Plato)
That looks pretty interesting, but it works and that's what counts Now you need to take a little clear silicone and seal up all the exposed connections to prevent dirt and moisture from creeping in and ruining your progress.
I take it that the twisted rear wire is just a retainer. Is that correct?
Carful the brand and formula used here. Some contain vinegar which as we know is an acid. Will corrode things in short order. Read the ingredients first.a little clear silicone
