Lawnboy18
- Jul 14, 2013
- 85
- 1,451
I brought the cheapo Tory-Bilt and I was able to mow the whole thing. I must say I did a pretty good job. I had one hand on the extreme end of the handle holding tha bail. My other hand was on the lower handle. I would use that hand to push the mower and keep it straight.
What would work there or what I would use would be The Turf Master or the Exmark 30" mowers. The weight of either of those mowers would give you better lines because they would hold the slope without sliding. That IMO would be the safest way and fastest.
I am not sure. There are different forces applied to the machine. I tried with the Ybravo, but it just kept sliding down and wanting to flip over. Another issue is turning around at the end of the line. You don't have much room to maneuver so a cheapo light mower can be swingned around to be able to mow back. Last that I would want is to turn around with a 200 lbs. mower.
I would just use my toro z480
Or any riding mower.
Well if I get a walk behind next year I could try it there.
When I start with the trimmer I trim off a good amount at the end to let me turn around easily.
I am just not sure about that 30" thing. It is just more weight that will be pushed towards the bottom logically.
Well if I get a walk behind next year I could try it there. When I start with the trimmer I trim off a good amount at the end to let me turn around easily. I am just not sure about that 30" thing. It is just more weight that will be pushed towards the bottom logically.
