I have been filing my blades for years, not taking to much off . and then more recently (3 years ago) i have been using a angle grinder because it is quicker for me,but i never used a balancer or even a nail set up like jd green uses(and jd does like most people and lawn service co's. do) which i think is a good thing. the thing is that if you don't balance the blade(s) "supposedly" you may experience vibration on the mower , which i never have felt. there is a mower blade sharpener/cleaner from ...magna-matic.. that is suppose to be the cats.....for sharpening and cleaning the grass and rust off the blade, but the price is (imo) so high that i dont see how a person can justify owning one.but many people on a different forum swear by them.
I have thought about using my angle grinder but would hate to take too much metal off a cutting edge so I don't do it that way. Do you use a metal grinding wheel of any certain grit? Coarse or fine?
its just a cheapie black and decker 4 1/2 " grinder with a black and decker wheel but no indication of coarseness(unless "type27" means anything) but by feeling it i'm saying med/fine....i'm sure you wont have a problem with your blades just practice on a old scrap piece of like steel and "finesse" it you'll be fine with it,:thumbsup:
I have been clamping mower blades in a vise to sharpen them with files for over 35 years, really, the only "Balancer" you need is a finish nail driven into a wood block. Just hang the blade on the horizontal nail and if the blade is unbalanced the heavy end will be lower. I have NEVER had an unbalanced blade, because by filing you remove so little material from each end the blade usually remains well balanced.
I bought one of those cheap balancers at the local hardware store and I guess it does ok.I had some rusty blades that I cleaned up with a wire wheel and then applied a coat of EZslide as a kinda experment. won't know how that goes till spring. russ
My good neighbor was giving me valuable advice and part of what he said was that it is important to always use a balancer. Is there any danger to the mower in general and if a balancer is not easily accessible can one make any modifications?
Pardon me for asking, but how can you use a Nail to balance a lawn mower blade when it doesn't achieve the center of rotation.
Good question. It is important to make sure the blade hole edge is centered on the nail to achieve a static balance. I do a double check and more than once the blade didn't balance the same twice because i hadn't centered the blade the first time. I am sure there is extra strength built in in engine lower bearings and spindles to compensate for some unbalance. You can balance a blade perfectly and one little stone can nick it, creating some the balance, and more nicks and sandblasting will uneven it more.
As you said you did a double check and more than once the blade didn't balance the same twice because you hadn't centered the blade the first time, nor can you put the blade back on the nail in the same place twice in a row.
I think it's a given fact that to balance anything you need to find center of what ever you're balancing and when you consider that the hole in a lawn mower blade can be 3/4 of an inch and you set it on a nail it would mean you're already 3/8 of an inch out of center to begin with so how can you balance the blade right.
Magna Matic, Oregon and other company's make blade balancing equipment and they are reasonably cheap and well worth the money if you're going to balance blades frequently and if you're a home owner replacement blades once a year are not that expensive. Not to be argumentative but I'll stay away from the nail myth thing.
The only place I have seen derogatory things said about the decades old method, nail or fixed pivot, is in manufactures marketing of their 'better idea'...
No matter how you do a 2 dimensional static balance it will be equally good...
If there were any benefit to a perfectly balanced blade you would find dynamic blade balancing ... As far as I know, no one has came up with that unnecessary service ... YET... :smile:KennyV
Here's a dynamic blade balancer for ya
Unnecessary? Hardly! ...
... I'm sold on dynamic balancing and nothing anyone says could change my mind.
I fully realize the price is out of reach for most homeowners but I own one of these balancers and sharpen/balance blades for others as well. It pays for itself.
It would have to pay for itself... Because That is Not a Dynamic Balancer... That's still a static balancer, tho with magnets and spring loaded cone....
But like I said any static balance will do an adequate job. There really is no need for Dynamic Balancing Mower blades.
There are a few gimmicky balancing systems available, Some handier to use than others, some very pricey, But they are all static balancers... I have Never seen a Dynamic (mower Blade) balancer.
But we are in a system where marketing will provide the Need for a product... so I'm fairly sure that eventually someone will market it, (needed or not), and like most everyone, I will have to check it out. Till then Pick the system that works Best for you & be happy that no one is trying to sway you into thinking you Need to Dynamically Balance a Lawn Mower Blade... Yet.... :smile:KennyV
There are several ways to use a static balancer... and there are various types available... any of them will give satisfactory results, I have yet to see a Dynamic, Mower blade, balancer, rotating looking for a heavy end is still a static single dimension balance system. Like I said some methods of finding a heavy end 'seem' to be more sophisticated than others... but it is still the same single plane principal, just using a different pivot for the same static results...
If you are happy with it, that is the Most important part...
A dynamic balance is Not needed and is impractical to achieve, (for a mower blade)...
For various reasons including those As MBTRAC pointed out...
There Are times when "good enough", is exactly that... good enough. and that is not just a short cut from the possible.... It is achieving a good functional & operational limit.
We are all "usually" mowing with a rotational speed under 4k RPM, static balancing by any method, will be good enough. :smile:KennyV
Crud accumulates at uneven rates on the blades throwing them off. I do note that the three bagger baskets fill better after sharpening and balancing. Guess I'll have to either sharpen or balance next time to see which is having the effect....and for a different perspective - Until today, I was completely unaware of blade balancing.
I've always just taken the blades off, hand filed til the edge is adequate, and tighten the blade back on the mower.
My little Honda self-propelled 5.5hp is over 15 years old (I can't recall precisely how much over) and never had a perfectly balanced blade except when I installed a new one. Over it's history it's had four blades in total. And, I've used the same method for my 46" lawn tractor with two blades.
Am I advocating using an unbalanced blade?
No, but not having perfectly balanced blades hasn't caused me any problems.
Though, now that I'm aware of balancing blades, I'll see what I can do or not...depends...
I...
Balance the blades dont seem to have effected the mowers very much, ...
No, it's still a static balancer (it's what I use.)Actually, the magnetic holder, tapered cone and blade spin on a bearing so in fact it Is a dynamic balancer.
Now when you cut grass your mower blades are going to build up with old dry grass and be out of balance to a small point anyways. So why would you want to spend big money to get them perfect?
I agree with Chance123, the blade will accumulate dirt and dried grass, but will continue to stay in balance. Any imbalance would tend to throw the grass off. Sort of like getting snow or ice on the tires of your car. It will only stick if there are no forces trying to throw it off. (Usually).Yes you should balance your mower blades when you sharpen them. But really how perfect can you balance a mower blade. Just look at what they are doing, cutting grass. Now when you cut grass your mower blades are going to build up with old dry grass and be out of balance to a small point anyways. So why would you want to spend big money to get them perfect?
Ok so how would the grass stay on the blade the same amount on both ends. As you cut grass the blade does and will not wear even on both ends.
The angle you sharping your blade at is more important than a perfect balance
Sent from my iPhone using LMF
A mower blade, By design will be UNbalanced during operation... The leading edge will be making contact with & cutting grass, that will load that end of the blade... The opposite end of the blade is in an area that has already been cut, or mostly cut. It will have less of a load than the edge that is cutting the bulk of the grass... So you could accurately say that the blade is dynamically Always Very out of balance...
But there will be those that will be Sure that their balancing systems are going to have an effect on this variable state of unbalance... especially if they are using a system that is sold for a lot of $$...
Fortunately balance is Not a very important element in making a lawn mower function & last... :smile:KennyV
Now your just being a wise ***chance123 said:This is where I lost the meaning of your statement
Wow, you guys really get stirred up over balancing, more even than sharpening. First time this forum I've seen a hint of profanity in the "***". :smile:
What we need is a cam corder with strobe video set up under the deck during operation to see what the blades are doing.
Next sharpening I will check the blade balance with dried grass-spinach on blade and them after scraped and wire brushed before sharpening to determine role of debris in static balance. I will use my $2.50 balancer (DIY) to detect imbalance down to 1/8 oz.
If we cannot resolve this issue peacefully here I suggest a BALANCE OFF" contest to be held in Kansas . No beer drinking allowed.:cool2:
marvc, spend another $1.50 and build the diy balancer shown in this forum. it will balance down to 1/8 oz on the star blades.
motoman,
WOW...just read this whole thread and all I can say is I vote for allowing beer at the BALANCE-OFF contest!! The first time I realized that balancing a lawn mower blade was important was right after watching the movie Sling Blade with Billy Bob Thornton:0)
I too began sharpening my lawn tractor blades with the cheap plastic cone balancer. I would use a wire brush, chisel and finally the wire brush on my bench grinder to clean the blade and then balance it as I sharpened it, rotating it on the cone several times to make sure it was good as was possible. I could easily see that this was not a "perfect balancing system"(but of course I didn't know about the less accurate nail method at the time...or the $200 Magna-Matic more accurate balancer). I was one of those that believed the myth that if I didn't do this annually my spindle bearings would be destroyed. But I'm not convinced there is any truth to that. I did, however, notice an improvement in the level of vibration I felt when riding the lawn tractor(or observed/heard in the deck) before/after sharpening & balancing just as mentioned by some other users. Sooooo...even the the cheap diy cone balancers must help "some". I'm still not convince(yet) that it is worth a $200 investment to improve the balancing with a Magna-matic. And I am certain that should I run over someone's head when mowing it's gonna result in a clean & straight cut that would make Billy Bob proud of me:0)
motoman,
An uneven load will impact balance ... a mower blade during its normal operation will always have an uneven load.
The importance of balancing (mower blades) is Greatly overrated. But, as in most things, if it makes you feel better, or pay closer attention to your maintenance procedures ... by all means do it... :smile:KennyV
...we are changing the dynamic balance, ie left to right,,...
I have had and use a balancer just like a magnamatic since 1992, and have found some blades horribly out of balance. When
I went to work at one of the largest dealers in Louisville, they had one of those little useless cones. I brought mine and mounted
it above my tool box, al of the mechanics would come and check their blades, The M Shop refused to buy one.
They also borrowed my Neway Valve tools, which got old, as those are tools that should be provided by the dealership.
They charged 8$ to reface a valve.
All they did was clamp it in a drill press and hold a piece of sandpaper on it!!!!!!!!!
This has been a great discussion, I have been thinking about all you guys have said and had an idea. When I owned a motorcycle I had a motorcycle wheel balancer that consisted of a stand with a steel shaft that sat on roller bearings. There were different sized aluminum cones that fit over the shaft and you would install a cone, slide the shaft through the wheel, install anther cone on the other side and sit the shaft on the roller bearings. I am going to dig that thing out of the shed, clean it up and see if the cones will work on my star hole blades. I'll let you know how it works.
Look in this forum for thread "that trick blade balancer cost how much..." It is a wooden version of your motorcycle wheel balancer.
I got a few minutes to experiment further with my spindle balancer. I started by using a torpedo level to adjust the face of my spindle to be perfectly plumb. I grabbed a different blade and put it on the nail and it went down on one side about three inches. I put it on the spindle and it went down about the same distance.
I then started grinding off the heavy end and got it level on the nail, even holding up a torpedo level to get it as level as possible. I then put it on the spindle balancer and it was dead level there as well.
I will be hustling tomorrow to catch up so I can take my wife to the doctor on Wednesday, so if I don't get a chance for more testing, I should be able to get back to it on Thursday.
If I were unable to do any further testing, my conclusion or at least what my testing tends to point toward, is that the nail method is worthwhile, and I see why it was actually published in some old John Deere manuals. It is CLEARLY better than no balance at all.
Larry
I use the gray colored blade balancer that looks like christmas tree to balance mower blades.
Let's face it, we're all a bit "unbalanced" anyway.
Because the wins control the air flow under the deck.
The wing ( flute to some ) errodes at the bend then cracks then breaks off and goes flying out at 14,000 ft/ sec.
Good enough reason ?
Electric mowers blades need to have a closer balance tolerance than gas powered, as the shafts and bearing surfaces are smaller and will cause problems with very little vibration.
I know this seems hard to believe, but the wing tips wear out faster than the cutting edge. When the wing tips wear out and break off (dangerous), there is no lift left on the blade so although the mower will cut the grass, it will not mulch leaving obvious grass clippings on the lawn. The first picture shows a line where the grass cuts a groove in the blade (by friction) which then eventually turns into a hole; the tip will then break off, noting the blade is about 6mm thick (1/4 inch). A mulching deck works by lifting the grass back into the deck and re-cutting the grass numerous times. The down side is that the blades wear out a lot quicker than a side discharge mower. The plus side is that there is no grass to dispose of; the mulch is like dust on a dedicated machine/deck so you cannot tell that the lawn has been mulched; and you are not taking anything away from the lawn (nutrients and water). Back to the original thread, from my experience, the higher wear rate on mulching blades means that they need to be sharpened and thus balanced more often than side discharge mowers. The second picture shows the end result.
