Overkill66
- Oct 15, 2015
- 1
- 4
Hello!
I have an Ex Mark Turf Tracer model TT5217KAEC with a 17 hp Kawasaki motor, (code FH500V-AS15), (E/WO FH500VB16243). It runs great but it leaks oil out of the top of the motor around the crank seal badly. I put in a new crank seal and it took that one out in a matter of hours. So it seems that the crank is moving around a lot and it's time to replace the engine.
I have found replacement engines for $1,500 to $2,000 range but that is more than I would like to spend as I only use it to mow my home (about 4-5 acres). This machine is awsome for the way it mows and does side hills.
Anyway, does anyone have a suggestion for a good motor that would be less expensive that I could convert it to. I am a pretty good fabricator and I can weld, wire etc. I was thinking a briggs twin as they should be plentiful used and parts would be easy to get. I would also like to keep the electric start feature I currently enjoy.
I am in the process of taking the motor off now.
I love this machine and it looks like the hydro system is completely separate and well out of the way. I would love to save it if I can afford it, because anything I replace it with would be a lot less machine.
I would greatly appreciate your thoughts!
