- Feb 19, 2020
- 122
- 12,910
Yes it would still have compression. There several seals and gasket involved. A two cycle uses the crankcase as part of the intake system/It has 120 psi compression, if the crankcase seal was bad would it still have good compression? Are you referring to the crankcase cover gasket?
Several parts places sell this coil (753-04336) for around $100 vs the eBay/Amazon $20 versions.. Sure wish I knew if that was it but it does kind of lead in that direction I guess.
I wish I hadn't thrown out the original coil, I can't believe I did that, I usually keep stuff forever.
And the coil should only cost $81.81 at a dealer. Below is my cost and resell price.
Now with the compression at 120 and the fact that the starter fluid caused the engine to run rich I would say that eBay coil is defective. Though it is a pain to get get to it would hurt to check the flywheel key. On this unit it made as part of the flywheel so if the damage a new flywheel would be needed. Be careful as it can look bad when it is not.
