Time Cutter deck lift pedal
I'm 6'4 and I use mine. But I'm way under 370 . I would think you could get a welder to weld on an extension to that pedal to fit you, or you could make one yourself and bolt it on if you're geared to the DIY type thing.
If you extend the deck lift pedal the floor board will not lift fully which makes belt changing a touch more difficult unless you cut a corner out of it .
Timecutter floorboard does not lift.. It is fixed.
Are you trying to make it further away or closer to you? I guess further away because you have long legs.
I"m not the one asking about making adjustments, I was just responding to a guy that said he was 370 lbs and could not press the pedal. It was him that was asking about making adjustments. In fact, I don't even see his post at the top, how'd that happen? I guess he removed it.
Oh Sorry, I got confused. I meant WiTimeCutter Its still on the top of page one.
