lawn mower fanatic
- Jun 8, 2012
- 6,749
Oh and lmf I believe that thing on one side is either blade or drive not throttle
Yeah that's what I meant...the drive.
You can not buy a better push mower than a snapper.
Every one else has tried and make a better cutting mower and has failed.
They are still the best mulching and bagging mower
Now I do not like their riding mowers. But if I ever was to get a zero turn it would be a snapper.
(( racing is the only sport that you need two balls ))
Now this may have been true years passed but not anymore. To many Company's too many mowers that are way ahead of Snapper. I kinda view Snapper like the Honda, they make a good mower yes and they have proven themselves in the residential market but until I see them being used in the commercial market I don't believe they are all that great a mower.
I feel like wheels are wheels. They wear out, either around the bolt, or the tread, and you have to replace them. You replace tires on your car every so often, and I don't see a difference with doing that for lawn mowers. Maybe we need some good pneumatic wheels, or even wheels with metal tread!:thumbsup:
The best 21 for commercial in my opinion is the toro proline. Hands down.
Well what do you think is the best 21 in. push mower for the commercial operator?
Cutting Options 2-in-1 (Side-Discharge/Mulch)
Material 14-Gauge
Construction Welded
Blades 1 Blade
Positions 7 Positions
Cutting Height 1.25-4.0 Inches
Front Axle Stamped Steel
Front Tire Size 8 Inch
Rear Tire Size 10 Inch
Tire Type Solid Rubber
HP/CC 190 cc
Torque 8.5 ft-lbs Net Torque
Fuel Tank Size 0.25 Gallon
Cycles 4-Cycle
Oil Filter Yes
Snapper CRP218520 (21") Commercial Ninja Self-Propelled Mulching Lawn Mower
Only $650.00.
