The Last Straw...Honda HRR Wheels
Carscw
I agree as far as walk behind and and zero turn mowers and especially for golf course or sports fields toro is number one ( I have a few toro mowers )
When it comes to a 21 inch push mower I still like snapper. ( do not like snapper rer )
(( racing is the only sport that you need two balls ))
Ric
If I had the choice between the Honda and the Snapper I'd pick the Snapper. Just do to the fact that it's a Forced Lubrication w/Filter. I my opinion any mower that incorporates a splash oil system isn't suitable for commercial use.
exotion
Cutting Options 2-in-1 (Side-Discharge/Mulch)
Material 14-Gauge
Construction Welded
Blades 1 Blade
Positions 7 Positions
Cutting Height 1.25-4.0 Inches
Front Axle Stamped Steel
Front Tire Size 8 Inch
Rear Tire Size 10 Inch
Tire Type Solid Rubber
HP/CC 190 cc
Torque 8.5 ft-lbs Net Torque
Fuel Tank Size 0.25 Gallon
Cycles 4-Cycle
Oil Filter Yes
Snapper CRP218520 (21") Commercial Ninja Self-Propelled Mulching Lawn Mower
Only $650.00.
<img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=16008"/>
I do like that mower and the price tag is good to. Is this the model that has the tube out the side into a bagger? Also does it have a bbc?
No BBC and no side tube since it's a Ninja Mulcher. I was thinking about getting this mower.
Carscw
Ok here's the deal but don't tell anyone
You can get a kit so you can bag.
If you ever get one I can look in my files and get the part number.
Now snapper will tell you they don't sell a kit for this mower but they do
I wish it could bag or I would probably buy it.
Or get this: HI VAC® Push Mower
Ric
If you are talking about that ninja CRP218520 it comes with a bagger? My problem with buying the mower is the fact it only has a 90 day commercial warranty.
The thing is as far as top rated mowers go you can visit ten different places and get a list of the top 10 rated mowers on the market and every list will be different and have different mowers.
But Honda is consistently on top. :licking:
exotion
I understand commercial warranty's but really commercial users (the smart ones anyway) are kinda small engine mechanics as a side effect and a warranty while nice but unnecessary because most problems can be taken care of by the user. I believe you should not run a lawn care business if you cannot fix and maintain your machines properly.
Warranty is good for the person who does not know how to fix things. This is one of many reasons I am ok with residential quality equipment as I can fix just about anything on them. Also my entire trailer full of equipment can be replaced with 1 grand easy if something crazy happened. The snapper here looks like a good quality machine and its in my price range (easily replaced) and its on my radar if and when my honda actually dies.
