BlazNT
- Apr 26, 2012
- 28
- 6,973
Re: MTD Yardman Transaxle Rebuild
Cat6 sucks to work with. My last wiring job was cat6. Go through the ceiling or put in plastic conduit under house. Only need to be connected to floor joist ever other one. Being plastic you can build it outside and put the wire inside with enough extra on each end to go into the walls. Then just take it under the house attach it to the floor joist and done.
You're talkin 60 feet of cable (cheap enough,) BUT I don't have a ceiling scuttle hole, goin underneath is a big headache too, that's why I'm considering powerline adapters, but some have to be on the same circuit/ breaker, most of our rooms are on separate circuits, and I sure as hell am NOT gonna install another circuit just for this, then,.. some say it doesn't matter.. any circuit is fine.. :confused2:..:confused2: AAARRRRRGGGGHHHH !!!! ( cat-6 is backwards compatible ) I was surprised how much is involved to do this, maybe I'll just keep the computer room hardwired, and go wireless to the Roku, maybe I can use the 5Ghz band for that, and use the 2.4 band for the puters N other stuff ..???
https://www.monoprice.com/product?c...0763&cjevent=5e5aaa1af25a11e88223097e0a240613
Cat-6 X 75 feet = $10.76
