BlazNT
- Apr 26, 2012
- 28
- 6,973
Re: MTD Yardman Transaxle Rebuild
Run a cable you will be glad you did. If your power goes through more than one breaker you will have nothing but problems. Just stick with cat5e.
Hey Guys, any of ya's "Streaming TV" savvy..?? I'm getting my equip. together to finally "cut the cord" seeking info on using powerline adapters, read alot, .. but it seems there's a lot of B/S on all this Equip. I have a dual-band router .. a good modem and certified cables, (HDMI & Cat-6 Ethernet) using Spectrum 100-Mbps. internet, and just got my Roku-Ultra (2018) got my head stuffed with info from the net, but deciphering the B/S from reality is the problem, I prefer to Hard-wire everything (as our computers, modem, router & printers are now, but now I need to get a signal from the Router, in the computer room, (1 end of the house) to the OTHER end of the house, (living-room) for Roku & TV, without the hassle of runnin an Ethernet cable all that way, HENCE, the use of powerline adapters ... thats what I really need info about, does any of the gang be usin a set-up like that ...?? :confused2:..:confused2::confused3:
View attachment 41665... View attachment 41666
