Boobala
- Feb 15, 2015
- 200
- 7,000
Re: MTD Yardman Transaxle Rebuild
Finally got all the parts for my pressure washer, now to see if the unloader valve was the problem, been into a lot of research on these things, and so much has changed in the past few years, I was surprised to see how complicated these things can get to be when you go into the pressure washing business, most awesome one I ever saw ( until now ) was when I worked at a Marina for Yachts, they have a 15,000 psi machine for blasting barnacles off the ships, ( most of the yachts were a minimum of 100 feet ) that thing could be heard a 1/4 mile away and you had to be at least 175 lbs. to work with it, and then you needed a break about every 10 min. to rest your arms from fighting the gun pressures, THAT is one helluva a machine. Anyway hoping to have my lil piss-ant 2200 psi machine going soon, time will tell the story ! .. :wink:
