Morning Ted, Stayers and Newbies.
From what you are saying you have too small of brakes in rear. Or too large of a booster/master cylinder. I have seen this a lot in cars and trucks where someone changed the front brakes without finishing the rear. Or your proportioning valve could be the wrong one. Do you know if your proportioning valve is adjustable? If it's not it's probably the factory one which it would make it the wrong one if the front has been changed.
I still have trouble reconciling things in my own mind.
All the combo valve knows is pressure,back pressure,and volume.
I would think that when the pressure to the rear brakes reaches a certain level relative to the fronts,
it would stop the flow to the rear and divert more to the front brakes.
Do small rear brakes lock up at a lower pressure than larger ones?
But still, as the caliper bores are the same in either system, and the caliper pistons really don't move much,I can't see how different size rear shoes/drums or booster assistance would make a difference.
I would consider plumbing an adjustable valve into the line, but my rear brakes are foe by a 1/4" line and I have yet to find a valve that size.
They pretty much all seem to be 3/16".
Hey Ron, Did you see my earlier post ........ https://www.lawnmowerforum.com/show...nsaxle-Rebuild?p=302178&viewfull=1#post302178
I will try to explain what I "think" I know about the valves. They are not valves as you would think of valves. They are holes of different sizes. Allowing different amounts of fluid to go through them. Smaller for rear brakes and larger for front brakes. 70% of the fluid/pressure to the front and 30% to rear in a balanced system. If either is larger or smaller the equation changes. The splitter in the rear does just that. Splits the pressure to each brake equally. Proportion valve, on the other hand, splits 70 30 if everything is correct. They make adjustable ones. I hope this makes sense.
