The Daily Yardman Thread
Boobala
Re: Latest garage door update
I prefer Dewey buttons covered in Hershey's milk chocolate,thank you!
PEOPLE in HELL WANT ice-water !! Wanna lose those ATTA-BOY's ... ??? I'll bet you didn't eat your Broccoli when you was a kid either !! ..:mad:
BlazNT
I spent yesterday installing finished wiring.
Up the stairway into the attic; back down again;
Repeat,repeat,repeat as necessary. (It was necessary a BUNCH!)
I was not able to run wires thru the ceiling between rafters as the attic is floored and insulated.
So, up the rafters, across the braces and down the rafters we went.
Poked a hole in the Hardibacker board ceiling for the old work outlet box and control wire.
I could not access my distribution box without taking down wallboard. Three are spaces available for more breakers,
but all knockouts in the top of the pox are populated with secured strain relief fittings. No getting in that way....
So, I wired it to the hot side of the attic light switch, which is on a 20a circuit with the doorbell transformer and smoke detectors.
I think the circuit can handle the 1/2hp motors.
I ran the control wire thru a utility closet and out the side which is the short hall out of the house into the garage.
I had to pursue any vias of opportunity in order to achieve a clean job.
Now, other than the metal skin on the top panel, Door #1 is complete!
In case anyone cares............
I'm giving you 5 more ATTA-BOY's!!!
BlazNT
Re: MTD Yardman Transaxle Rebuild
Total views 501
BlazNT
Morning Ted, Stayers, and Newbies.
This is a picture of the sunrise in Alaska in June. Seeing that the sun does not set, it is an interesting picture.
Boobala
Hey There Chuck ! Good Mornin to ya !! .. YESS.jpg .. odd pic you posted, but neat !
The thought 4 2day : .. https___s3_amazonaws_com_tanga-images_q3zdtpkvn4jw.jpg
Boobala
Your "thought 4 2day" was created by a man because a woman would have said Torture.
:laughing:..:laughing:..:laughing:..:laughing:..:laughing:..:laughing:
NorthBama
Good morning folks i drop by occasionally
Boo gets up early but i bet he pops the recliner in low gear for a nap after lunch. :laughing:
Boobala
You got me "pegged" there "James Lewcious" , but these days, with the great workin weather (Central Fl.) I been skippin those afternoon siesta's, trying to catch up on everything left-over from last fall. Can't believe I seem to have accomplished more, when I had a full-time job to contend with. ..:confused2:
You need to visit MORE OFTEN ya schitt ! .. :welcome:
