Re: Garage Doors
So, Ron..
How has the garage door installation gone so far? In my minds eye I see a possible problem with having panel strips of differing widths, but maybe that doesn't matter. Are the door-width panel strips made up of individual panels? Or are they just made to 'look' like they are? You mentioned aluminum, maybe the panel strips are flat pieces?
I'm still working out how you can reduce the height of one panel strip, but not knowing what they look like, makes my mind puzzle over the numerous styles of garage doors I've seen in my lifetime and that gives me too many possibilities to work with.
I wonder if the radius of the 90 degree turn at the top of the track has some bearing on the height of each panel strip as each one has a guide wheel and again, if the space between guide wheels is too close together, I wonder of they might jamb trying to negotiate that turn in the track. I tried drawing it out, it 'looks' like it will work alright, smaller panels would actually allow for a tighter turn, like a tambor door.
How about some pictures, you know the rules here on the site, you must provide detailed pictures and model numbers if you expect to get any usable feedback. (Other than being told to raise your ceiling, or jack up your garage.)
Roger
Hey, Rog,
Well. door #1 is partially completed: tracks shortened and installed, 4ea 19" panels installed, torsion spring installed and tensioned.
The door goes up and down just fine, leaving a 7" gap at the top.
Spring tension is a bit high, but that should work itself out after the weight of the remaining panel comes into play.
I am going to obtain a 1 x 8 board for testing purposes.
If it looks like the door will be operable with the short panel at the top, I'll trim the panel out to not look so patchwork
and install there. I may actually be able to affix it to the top of the existing metal door panel and it may clear everything as it swings inward.
If not, I'll hinge and roller it.
Then I have to determine where to attach the opener...
I'm sure it would work fine in the middle or at the bottom, but the bottom metal panel has the seal affixed with numerous spot welds, so removal is not a viable option.
The steel door is a typical unit made to look like is comprised of raised panel, style and rail construction which is embossed into the thin steel skin.
like this:
https://www.lowes.com/pd/Pella-Traditional-108-in-x-84-in-White-Single-Garage-Door/50259747
Putting the short panel in the middle would work, just look funky.
As there will be 2 doors side by side, symmetry is an issue.
Pics may follow later.........
