Re: Garage Door
Ron,
It sounds like good-old tried and true, "Trial and Error" has come through for you, or is at least showing you the way to 'garage door happiness'. I will be interested in hearing how things go in the end..
Perhaps you'll write a book afterwards: "The Zen of Garage Door Repair" . . . . . Bet it would be on the NY Best Seller List for weeks!
Good luck!
Rog
Back in my youth, I enjoyed building model cars. There was a technique known as "kit bashing" in which parts from different car kits
were adapted to make your car custom.
I was never any good at it............
This is more like "garage door bashing" or otherwise known as "I'll make it fit"
I'm gonna pick up some spruce today to make a full size panel.
Poplar would be better, but more expensive and farther away..........
Maybe for my wife's door....
Then comes the opener and non-present wiring........
Actually there is sensor wiring---for a single 24' door, which was WAY too expensive to contemplate.
The 2 x 9 footers will work fine.
This all started when we stopped by a new neighbor's garage sale.
I said that I could use the doors................
