Dave T S
- May 23, 2022
- 27
Thank you.You will likely still see the original cross hatch in the engine and they probably won't be any scores at all but if you see a few vertical ones as long as there's not five or six around the bore and as long as they're just fairly small and you can't really catch your fingernail in them too much it's not really a concern.
For that base gasket or some gasket or what do they call it, they usually don't leak a lot there but I have found tricks to fix them.
I had several of the Kohler XT engines come in that were leaking down there.
You tilt The Mower and whichever side or angle you need to so there's no more oil puddling on the inside there and then blast it with carb cleaner three or four times and with compressed air to get all the oil off the area... Then you can take some of the good RTV like the ultra stuff that's more oil resistant and spirit and push it right into the gasket area.
Some of these are so hidden that I had to use it on the tip of a screwdriver but as long as you push it in there with a wiping motion and then I usually go back and dab some more on top but still pushing it on top and then leveling it out to the sides.
I think I've done three of the colors so far maybe four and not have one of them leaked afterwards
I left them up in the air like that to dry overnight and then set them back down and started them.
If it works it works.
