Dave T S
Hello,
I have a lawn boy #10685 self propelled mower, with a Tecumseh LV195SE engine, spec 362044D, that will not turn over. There is spark and I see that the primer is operating as it is bringing fuel into the carb. I've replaced the plug, coil, oil and other non related items. I've tried to start it with "starting fluid" and that doesn't do a thing. Could it be low compression? Thanks for your help and idea's.
