If everything is in good working order , then electrically it makes no difference.
If your mower was wired up for electric engine braking then it should go to the A terminal on the ignition switch.
Practically it is easiest to wack an eye terminal on the wire and pop it on the hot solenoid terminal.
Caveat is if a diode goes bad in the rectifrier then it will drain the battery to death.
