djdicetn
- Sep 3, 2012
- 2,193
Carscw,I do not use a striping kit. As I said before I pitch the front up higher than the back if the back is higher than the front then the deck will not lay the grass down. Even on my push mowers I don't use a kit. Snapper push mowers just stripe the best. If you want to run a kit you can make your ow. If you want to stripe a big area like a ball field drag some chain link fence behind you.
I know someone will say something dumb about the chain link fence but that's what the pros use
(( racing is the only sport that you need two balls ))
Thanks for the additional advice on striping!!! Yeah, you were one of the few responders on the Blade Pitch. Don't get me wrong, it's not that I doubt your advice on "heeling the deck", I just want to get as many opinions(especially, those like you that actually practice the alternative method...or have done both and can give an unbiased comparison) about the blade pitch and/or striping before I try something. I definitely value your feedback and will take it into account!!!!!
