Fish
- Aug 2, 2013
- 11
- 5,143
Like I said, when an engine overheats the valve area of the block will warp back and make the clearances closer, so grinding valve stems will be needed.
The block warping away also cocks the seats, so they don't seal properly, a correct valve job is the best repair.
To do a correct valve job, cutting the valves and seats is the correct way, and of course,
cutting the valves and seats, you need to grind the valve stems as well........
I use the Neway carbide cutting system.
Not many techs do it the way they should, they just slop on some valve paste and lap the heck out of them.
I was interested how you were removing and re-installing the springs and keepers, it is a pain to do it without valve tools,
what was your technique?
