mechanic mark
- Jul 15, 2013
- 176
- 7,494
Just for reference but why does 846108 not fit?
Is the difference that one is single and one is a double barrel carb?
The answer to your first question is yes it would probably fit.
The answer to your second question is absolutely not, you know being a Master Technician for B&S that engine model & code numbers are necessary for locating correct part. I have talked to B&S Corporate USA as well as technicians & B&S parts folks around the country & they say no longer available & no substitution for carburetor 808728, 807961, 808255. Just because a carburetor will fit & bolt up does not mean it will function properly on various engines, I know you know this. I have emailed & called numerous times asking if 846108, 846280 & other carburetors asking if they would work & function properly, the answer is always no. Thanks pugaltitude for your help in this matter, mechanic mark
