lawn mower fanatic
- Jun 8, 2012
- 6,749
I kinda have to agree a cruise control is nothing more than a gimmick if people have lots of sensitive areas they should learn how to trim... It's not hard just don't squeeze like your king Kong there is a throttle control on every trimmer learn how to use it if I was going to spend that much money I would get a better built stihl or echo .... Imo
It has a dial built on the trigger.... you roll the dial either forwards or backwards to increase or decrease how it will let you pull the trigger ranging from not at all to all the way full throttle.
say you set the dial at the half way point, the trigger will only let you pull it to half way and then if you desire full throttle you just squeeze harder and the trigger breaks loose and lets you pull it full throttle. once you release the trigger and pull it again it goes back to where you have the "cruise control" set.
its a standard trigger just different mechanism internally.
Well its finally here the new fs94 is out i stop by my dealer today an they have 10 in stock an there selling for 360 before tax an i am also told sold drive shaft an 29 cc motor cant wait to try one out. :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
